- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl identity
- uipathctl identity add-host-admin
- uipathctl identity enable-basic-auth
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl sso
- uipathctl sso generate-connector
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
If you use Active Directory (AD) and are planning on upgrading to 2023.4.0, we highly recommend that you skip straight to the 2023.4.3 version, as 2023.4.0, 2023.4.1 and 2023.4.2 are impacted by an AD issue.
Automation Suite on AKS/EKS consists of multiple components. Both you as a customer and UiPath share responsibility of these components. For details, see Compatibility matrix.
You are responsible for upgrading:
- Kubernetes infrastructure where Automation Suite is deployed (AKS or EKS)
- Components that you choese to bring as part of Automation Suite (e.g., Gatekeeper, FluentD, etc.)
UiPath is responsible for upgrading:
- UiPath services (e.g., Orchestrator)
- Components deployed as part of Automation Suite (e.g., ArgoCD)
You are responsible for upgrading the Kubernetes infrastructure hosting Automation Suite. You should follow the standard practices of your company to upgrade Kubernetes infrastructure.
