uipathctl Reference Guide
Last updated Nov 11, 2024
uipathctl cluster maintenance disable
Disable maintenance mode for the cluster.
uipathctl cluster maintenance disable [flags]uipathctl cluster maintenance disable [flags]
Options
-h, --help   help for disable  -h, --help   help for disable
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
