- 入门指南
- 了解 UiPath Robot
- UiPath Assistant
- 安装要求
- Installing robots for unattended automations
- 先决条件
- 使用 UiPath.Robot.msi 安装
- 使用 UiPath.Studio.msi 安装
- Installing with Command Line Interface
- 使用部署模板安装
- Deploying the Robot to multiple machines
- Licensing robots for unattended automations
- 更新 UiPath Robot
- Configuring robots for unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- 集成
- 故障排除
To execute unattended automations, you need to allocate one or more robot licenses (or runtimes) to your robots, specifically to the machine that hosts your robots. The number of runtimes assigned to a machine represents the execution capacity. For example, with one runtime, you can execute only one unattended automation at a time. With five runtimes, you can execute up to five unattended automations at the same time, on the same host machine.
The following runtimes are available for unattended automations:
Unattended (Production)
非生产
测试
To license a robot for unattended automations, first upload and activate a license in Orchestrator, then connect the robot to that Orchestrator instance.
To connect a robot to Orchestrator, you need to know the client credentials (client ID and secret) generated by the machine object in Orchestrator.
In the Assistant, use the Client ID connection type, and provide the client credentials.
In the Command Line Interface, use the
--connect
command, and provide the client credentials.
activate
command in the Command Prompt. The license activation can be done offline and online.
Check out the LicenseTool utility for more commands and parameters.
UiPath.LicenseTool.exe
is found, and 1234-5678-9010-1112
is the license string.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate -l 1234-5678-9010-1112
is found, and c:\Downloads\license.txt
is the path to the license file.
C:\Program Files\UiPath\Studio\UiPath.LicenseTool.exe activate-offline -f c:\Downloads\license.txt
