- 入门指南
- 了解 UiPath Robot
- UiPath Assistant
- 安装要求
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- 集成
- 故障排除
使用 UiPath.Studio.msi 安装
UiPath.Studio.msi
installs Studio, Robot, and Assistant.
First, download the installer from Automation Cloud™ Resource Center, or from the Product Downloads section in Customer Portal. Look for the following entries:
For Enterprise versions - UiPath Studio 2024.10
For Community versions - UiPath Studio, Robot, Assistant (Community Version)
Once the download is complete, continue with the following steps.
- Launch the installer.
- Read and accept the License Agreement, which includes the UiPath terms of use for activity packages and their dependencies.
- Select the type of installation: Quick (recommended for Community Users) or Custom (recommended for Enterprise/Advanced Users).
If you select Quick (recommended for Community Users), continue the installation by selecting Install.
For Custom (recommended for Enterprise/Advanced Users), continue by selecting Configure and following the remaining steps.
- In the Select install mode section, decide who should be able to use the attended installation:
Install for me only - Installs Studio, Robot, and Assistant in the user profile folder. No administrator privileges needed. Follow step 6 for options on installation packages.
Install for all users on this computer - Installs Studio, Robot, and Assistant for all users on the machine. Needs administrator privileges. Follow step 9 for options on installation packages.
- Select Choose packages.
- For Install for me only installations, decide what software to install for running attended automations:
Automation Developer - Installs Studio, StudioX, Robot, and Assistant. Follow step 7 for advanced settings.
Attended - Installs Robot and Assistant. Follow step 8 for advanced settings.
- To customize the Automation Developer installation, select Advanced Settings. Then customize the following settings:
- For Installation Package:
- Orchestrator URL
The URL of the Orchestrator instance to connect to using Interactive Sign-In. This value is saved in the
uipath.config
file. - Automatically sign in
When your environment is configured to use SSO with Azure Active Directory, select this option to enable automatic authentication for your account.
- For Extensions, select the extensions you want to install. By default, the StudioX Excel Addin, UiPath JavaScript Robot Add-on, Chrome, and Edge Chromium extensions are installed.
- Packages configuration
Select the Disable Online Feeds option if you want to disable the Official and Marketplace online feeds for activity packages. Recommended for offline environments.
- For Security, select the security options for your installation:
- Enforce Signed Execution
Instructs the Robot to execute signed packages exclusively.
- Disable Secured XAMLs
Disables security of XAML files for Robots installed as a Windows service. Unsecured XAML files allow users to read and modify the process files and logic.
- Disable Telemetry
Disables the collection of anonymous usage data for Studio and Robot.
- To customize the Attended installation, select Advanced Settings. Then customize the following settings:
- Orchestrator URL
uipath.config
- For Extensions, select the extensions you want to install. By default, the UiPath JavaScript Robot Add-on, Chrome, and Edge Chromium extensions are installed.
- Disable Telemetry
- For Install for all users on this computer installations, decide what software to install for running attended automations:
Automation Developer - Installs Studio, StudioX, Robot, and Assistant. Follow step 10 for advanced settings.
Attended Robot - Installs Robot and Assistant. Follow step 11 for advanced settings.
- Installation Path
The destination folder for installation, other than the default one in
%ProgramFiles%
. - License Code (optional)
The key for your standalone trial or enterprise license. Without a key during a the standalone trial setup, Studio prompts for it upon its first launch.
- Orchestrator URL
uipath.config
- Automatically Starts Assistant with Windows
Launches Assistant at Windows startup.
- Host for SAP Solution Manager
Available if you have the SAP connector for Microsoft is already installed on your machine. If selected, you need to provide the hostname or IP address for your SAP Solution Manager instance.
- Default download location
- The download location for activity packages. Default location is
%userprofile%.nuget\packages
. - Packages configuration
- Disable Telemetry
- To customize the Attended Robot installation, select Advanced Settings. Then customize the following settings:
- Installation Path
%ProgramFiles%
- Orchestrator URL
uipath.config
Enabled by default, launches Assistant at Windows startup.
- Disable Telemetry
- 选择“安装” 。
