robot
- 入门指南
- 了解 UiPath Robot
- UiPath Assistant
- 安装要求
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- 集成
- 故障排除
Admin Guide
Last updated 2024年10月21日
使用部署模板安装
Azure 市场部署允许您直接从 Azure 门户部署 UiPath 解决方案。
Deploying through Azure Market creates a modern folder in Orchestrator. This folder comes with assigned user accounts and machine templates. The solution structure has the following naming:
- 文件夹:
AzureDeployed
User account (one for each deployed robot):
Azure-<VM Name>-<RandomString>
Robot account (for each user):
<VM Name>\<Machine Admin Username>
- Machine template (one for each deployed robot):
AzureTemplate-<VMName>
The Azure Portal wizard allows you to deploy one or more Robots. It uses a Windows Virtual Machine, which runs scripts to configure the Robot and connect it to Orchestrator. The machine, together with a Network Interface Card and a separate storage account, is deployed within a virtual network.
To deploy robots using the Azure Portal wizard:
