uipathctl reference guide
上次更新日期 2025年2月24日
uipathctl manifest apply
描述
加载在 PATH 中找到的配置,并将其应用于集群。
该命令在集群的当前状态和所需状态之间执行差异,并将更改应用于集群。
当存在 --override 标志时,列表将覆盖在输入文件中找到的选择。 该标志与 --only 标志互斥。 当输入文件中存在 exclude_components 键时,列表中找到的组件将从已安装的组件中排除。 它的优先级高于所有其他标志,并且与其中任何标志都不互斥。
uipathctl manifest apply PATH [flags]uipathctl manifest apply PATH [flags]
示例
# Apply the configuration found in input.json, using the versions found in versions.json
        uipathctl manifest apply input.json --versions versions.json
        # Apply the configuration and specify the kubeconfig file to use
        uipathctl manifest apply input.json --kubeconfig cluster.kubeconfig --versions versions.json
        # Simulate the apply command and print on stdout the result of the operation
        uipathctl manifest apply --dry-run input.json --versions versions.json
        # Apply the configuration but skip the components installed directly by helm
        uipathctl manifest apply --skip-helm input.json --versions versions.json
        # Apply the configuration overriding the initial list of components
        uipathctl manifest apply --override automation_hub,orchestrator --versions versions.json
选项
--continue-on-error   if true, continue applying the manifest even if an error occurs
--dependencies-only   if true, only dependencies will be applied
--dry-run             if true, just print the result of the command, without applying it
--fail-on-version     if true, fail if the version of the component is not found in the versions file
  -h, --help                help for apply
--no-wait             if true, return immediately after the ArgoCD applications are created
--only strings        optional exclusive list of components to apply
--override strings    optional list to override the components enabled in input.json file
--skip-dependencies   if true, dependencies will be skipped
--skip-helm           if true, skip components installed directly by helm
--versions string     path to versions file--continue-on-error   if true, continue applying the manifest even if an error occurs
从父命令继承的选项
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • 描述
  • 示例
  • 选项
  • 从父命令继承的选项
此页面有帮助吗?
获取您需要的帮助
了解 RPA - 自动化课程
UiPath Community 论坛
信任与安全
© 2005-2025 UiPath。保留所有权利。
