uipathctl 参考指南
uipathctl prereq run
描述​
运行先决条件检查,以验证安装能否成功。
uipathctl prereq run PATH [flags]
示例​
        # Runs all the prerequisite checks
        uipathctl prereq run input.json --versions versions.json
选项​
  -h, --help              help for run
--versions string   path to versions file
从父命令继承的选项​
--excluded strings    components to be excluded from execution, defaults to none
--included strings    components to be included in the execution, defaults to all
  • 描述​
  • 示例​
  • 选项​
  • 从父命令继承的选项​
此页面有帮助吗?
连接
需要帮助? 支持(opens in new window)
保持更新
