- 概述
- 预安装
- 安装
- 集群管理
- 备份和还原
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- 证书管理
- 升级
- 身份验证
- uipathctl sso
- uipathctl sso generate-connector
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl identity Enable-basic-auth
- 监控和警示
- 特定于产品的配置
- 故障排除
请注意此内容已使用机器翻译进行了部分本地化。
新发布内容的本地化可能需要 1-2 周的时间才能完成。
uipathctl 参考指南
上次更新日期 2024年11月11日
为结构的 SSO 部署生成 Kusdomize 覆盖。
uipathctl sso generate-overlays [flags]
Generate the overlays for a HA deployment of both ArgoCD and Dex, loading RBAC from a file
uipathctl sso generate-overlays --argocd-base ha --dex-base ha --argocd-url <https://argocd.local:30001> --rbac-file test-policies.csv --connector-file connector.yaml --dex-url <https://dex.local:32000> --kustomize-root ./hack/test/sso/kustomize
--argocd-base string ArgoCD kustomize base directory to use
--argocd-url string The externally accessible URL for ArgoCD (must include port if not standard for protocol)
--connector-file string Path to the Dex Connector's configuration file
--dex-base string Dex base kustomization to use
--dex-url string The externally accessible URL for Dex
--dex-use-https Optionally use https for Dex
-h, --help help for generate-overlays
--kustomize-root string Kustomize root directory
--rbac-file string Optional file to load the RBAC config for ArgoCD from (Overwrites policy.csv in the argocd-rbac-cm ConfigMap)
