不在支持范围内
uipathctl 参考指南
上次更新日期 2025年4月29日
uipathctl manifest get
描述
在标准输出上打印在集群中观察到的当前清单。格式始终为 YAML
该命令将默认为 kubeconfig 文件中的当前上下文。如果设置了 --kubeconfig 标志,则它将使用标志指定的 kubeconfig 文件。如果没有其他标志,输出中不包含集群范围内的配置和依赖项。
uipathctl manifest get [flags]uipathctl manifest get [flags]
示例
        # Get the current manifest observed in the cluster, without dependencies or cluster wide configurations
        # Get the current manifest from the cluster identified by the current context in the kubeconfig file
        uipathctl manifest get --kubeconfig /root/kubeconfig
        # Get the current manifest, including the cluster wide configurations and the dependencies
        uipathctl manifest get --include-config --include-dependencies
选项
  -h, --help                   help for get
      --ignore-errors          ignore errors when getting the manifest
      --include-config         include cluster wide config in the diff
      --include-dependencies   include dependencies in the diff
  -o, --output output          output format. one of [json,yaml] (default yaml)  -h, --help                   help for get
从父命令继承的选项
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • 描述
  • 示例
  • 选项
  • 从父命令继承的选项
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
