- Démarrage
- Comprendre UiPath Robot
- Assistant UiPath
- Prérequis d’installation
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Connecting robots for unattended automations to Orchestrator
- Configuration de Windows Server pour des Robots haute densité
- Rediriger les Robots vers un serveur proxy
- Implementing authentication
- Adjusting registry settings for execution in minimized RDP windows
- Using network locations
- Configurer des Robots Linux
- Configuration de la vérification de la signature des paquets
- Configurer des dossiers de package et des chemins d’accès réseau
- Configurer des flux d’activité
- Deploying unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- Intégrations
- Résolution des problèmes
Installer via des modèles de déploiement
Deploying Service Mode Robots on AWS infrastructure allows you to run unattended automations on Amazon EC2 instances.
Les options de déploiement suivantes sont disponibles :
Les déploiements place de marché Azure vous permettent de déployer des solutions UiPath directement à partir du portail Azure.
Deploying through Azure Market creates a modern folder in Orchestrator. This folder comes with assigned user accounts and machine templates. The solution structure has the following naming:
- Dossier :
AzureDeployed
User account (one for each deployed robot):
Azure-<VM Name>-<RandomString>
Robot account (for each user):
<VM Name>\<Machine Admin Username>
- Machine template (one for each deployed robot):
AzureTemplate-<VMName>
The Azure Portal wizard allows you to deploy one or more Robots. It uses a Windows Virtual Machine, which runs scripts to configure the Robot and connect it to Orchestrator. The machine, together with a Network Interface Card and a separate storage account, is deployed within a virtual network.
To deploy robots using the Azure Portal wizard:
