- Erste Schritte
- Grundlegendes zu UiPath Robot
- UiPath Assistant
- Installationsanforderungen
- Installing robots for unattended automations
- Configuring robots for unattended automations
- Connecting robots for unattended automations to Orchestrator
- Einrichtung von Windows Server für High-Density-Roboter
- Weiterleitung von Robotern über einen Proxy-Server
- Implementing authentication
- Adjusting registry settings for execution in minimized RDP windows
- Using network locations
- Einrichten von Linux-Robotern
- Konfigurieren der Paketsignaturüberprüfung
- Einrichten von Paketordnern und Netzwerkpfaden
- Konfigurieren von Aktivitätsfeeds
- Deploying unattended automations
- Installing robots for attended automations
- Configuring robots for attended automations
- Integrationen
- Fehlersuche und ‑behebung
Installieren mithilfe von Bereitstellungsvorlagen
Deploying Service Mode Robots on AWS infrastructure allows you to run unattended automations on Amazon EC2 instances.
Die folgenden Bereitstellungsoptionen sind verfügbar:
Mit Azure Marketplace-Bereitstellungen können Sie UiPath-Lösungen direkt über das Azure-Portal bereitstellen.
Deploying through Azure Market creates a modern folder in Orchestrator. This folder comes with assigned user accounts and machine templates. The solution structure has the following naming:
- Ordner:
AzureDeployed
User account (one for each deployed robot):
Azure-<VM Name>-<RandomString>
Robot account (for each user):
<VM Name>\<Machine Admin Username>
- Machine template (one for each deployed robot):
AzureTemplate-<VMName>
The Azure Portal wizard allows you to deploy one or more Robots. It uses a Windows Virtual Machine, which runs scripts to configure the Robot and connect it to Orchestrator. The machine, together with a Network Interface Card and a separate storage account, is deployed within a virtual network.
To deploy robots using the Azure Portal wizard:
