- Release notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
UiPath Assistant Connection
Automation Hub User Guide
Last updated Apr 15, 2025
If you have Instant Consumption enabled, then once the GET button is pressed in the Automation Store, the automation will automatically be available for running in UiPath Assistant.
In order to setup your UiPath Assistant organization wide, you need to make sure that the following setup is in place:
To see and run your Automation in UiPath Assistant, see the steps below:
Open your UiPath Assistant that is already connected to the Orchestrator that corresponds to the same tenant as the Automation Store.
In the processes list, you are able to see the newly installed process from the Store and you can run it for the first time.
