Automation Hub
- Release notes
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Share Idea or Automation
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Starting as an Idea Approver
Automation Hub User Guide
Last updated Apr 19, 2024
After successfully logging in, you, as an Idea Approver should focus on the following tasks:
- check out the shared ideas by accessing the Workspace > Automation Pipeline > Review.
- within the same page, check the list of ideas and identify any potential duplicates in order to facilitate the review process.
You are encouraged to Share your own ideas or components that will boost the company’s RPA assimilation.
- view the and choose to follow the ones that drow your attention,
- check out and download the components shared within your tenant,
- access the Leaderboard.
