- 发行说明
- 2.2510.1
- 2.2510.0-patch2
- 在开始之前
- 管理访问权限
- 入门指南
- 集成
- 使用流程应用程序
- 创建应用程序
- 正在加载数据
- Transforming data
- 自定义仪表板
- 发布仪表板
- 应用程序模板
- 通知
- 其他资源
Process Mining
发布日期:2026 年 3 月 16 日
This patch resolves issues affecting data loading and application editing in Process Mining deployments with large datasets.
Uploading data failed for applications with a large number of columns. During data operations, Process Mining queries the database to retrieve column names and data types. For applications with many columns, the resulting output exceeded the 8,000-character limit in Microsoft SQL Server, which caused the upload to fail with a SQL error. Process Mining now handles large column sets correctly and data uploads succeed as expected.
Applications with more than 500 fields could no longer be edited. Process Mining enforces a 500-field limit per application. During the initial run, the system automatically added newly discovered fields. Incorrect field counting allowed the total to exceed the limit, after which the application could not be saved or edited. Field counting now works correctly, and applications remain editable within the defined limit.
Data refreshes after the initial CDATA ingestion did not load new data into the ELT editor or dashboards, with no error reported. When the data mapping was unchanged between ingestions, an incorrect check bypassed the mapping execution step for CDATA tables, which write directly to the database rather than through blob storage. As a result, subsequent ingestions appeared to complete successfully but continued to display data from the initial ingestion. The check is now corrected, and CDATA data refreshes load updated data as expected.
