studio
2020.10
Studio User Guide
Group Policies
If your organization uses Group Policies for browser extension management then follow the instructions from this page to ensure that the extension for Edge is installed correctly.
The list of active policies on your machine can be viewed in Edge by navigating to edge://policy.
You can find out more information about Edge policy management on this page.
Group Policies That Affect the UiPath Extension for Edge​
ExtensionInstallForcelist​
The ExtensionInstallForcelist policy controls which extensions are force-installed in the browser.
This policy must contain the ID of the UiPath Extension for Edge.
For machines that are joined to a Windows Active Directory follow the installation steps for the Group Policy Offline installation method.
For this installation method the ExtensionInstallForcelist policy must contain the value:
ndmegdjihnhfmljjoaiimbipfhodnbgf;file:///C:/ProgramData/UiPath/UiPath.Common/EdgeExtension_SelfHosted/extension_manifest_edge.xml
For machines that are not joined to a Windows Active Directory follow the installation steps for the Group Policy Online installation method.
kcgmcmhhfbcacnlnopghneecffhelmhe;https://edge.microsoft.com/extensionwebstorebase/v1/crx
DeveloperToolsAvailability​
If the UiPath Extension for Edge is installed using Group Policy then the DeveloperToolsAvailability policy must be set to the value 1 (Allow usage of the Developer Tools) to enable the full extension functionality.
See more details about this setting in the troubleshooting page.
NativeMessagingBlocklist​
The NativeMessagingBlocklist policy prevents the UiPath NativeHost (ChromeNativeMessaging.exe) from working.
You can allow the UiPath NativeHost by adding the value com.uipath.chromenativemsg_v2 to the NativeMessagingAllowlist policy.
ExtensionInstallBlocklist​
The ExtensionInstallBlocklist policy prevents extensions from being installed on the machine.
To fix this, you can either:
  • Install the UiPath Extension using Group Policy.
  • Or allow the UiPath Extension to be installed from the Edge Web Store by adding the value kcgmcmhhfbcacnlnopghneecffhelmhe to the ExtensionInstallAllowlist policy.
NativeMessagingUserLevelHosts​
If the NativeMessagingUserLevelHosts policy is set to false, it prevents the UiPath extension from working correctly in the case it was installed without administrator privileges.
  • Set the NativeMessagingUserLevelHosts policy to true.
BlockExternalExtensions​
If the BlockExternalExtensions policy is set to true, it prevents the UiPath extension from being installed in any other way except for by policy.
To fix this you can either:
  • Set the BlockExternalExtensions policy to false.
ExtensionAllowedTypes​
If the ExtensionAllowedTypes policy is set, it prevents the UiPath Extension from being installed. To fix this, you must add the value extension to the ExtensionAllowedTypes policy.
ExtensionSettings​
If the ExtensionSettings policy is set to block all extensions it will prevent the UiPath Extension from being installed.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
