- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Group Policies
Group Policy configuration for the UiPath Extension for Edge: ensuring correct installation in organizations that manage browser extensions via policy.
If your organization uses Group Policies for browser extension management then follow the instructions from this page to ensure that the extension for Edge is installed correctly.
The list of active policies on your machine can be viewed in Edge by navigating to edge://policy.
You can find out more information about Edge policy management on this page.
Group Policies that affect the UiPath Extension for Edge
ExtensionInstallForcelist
The ExtensionInstallForcelist policy controls which extensions are force-installed in the browser.
This policy must contain the ID of the extension for Edge.
- For machines that are joined to a Windows Active Directory follow the installation steps for the Group Policy Offline installation method. For this installation method the ExtensionInstallForcelist policy must contain the value:
ndmegdjihnhfmljjoaiimbipfhodnbgf;file:///C:/ProgramData/UiPath/UiPath.Common/EdgeExtension_SelfHosted/extension_manifest_edge.xml
- For machines that are not joined to a Windows Active Directory follow the installation steps for the Group Policy Online installation method. For this installation method the ExtensionInstallForcelist policy must contain the value:
cdfjcmjmgdnojgaojdnefhjjpaijapci;https://edge.microsoft.com/extensionwebstorebase/v1/crx
NativeMessagingBlocklist
The NativeMessagingBlocklist policy prevents the UiPath NativeHost (ChromeNativeMessaging.exe) from working.
If the NativeMessagingBlockList policy is defined with the value of *, it means all native messaging hosts are denied, unless they are explicitly allowed through the NativeMessagingAllowList policy.
NativeMessagingAllowlist
The NativeMessagingAllowlist policy specifies which native messaging hosts are not subject to the deny list.
A deny list with the value of * means all native messaging hosts are denied. You can allow the UiPath NativeHost by adding the value com.uipath.chromenativemsg_v2 to the NativeMessagingAllowlist policy.
ExtensionInstallBlocklist
The ExtensionInstallBlocklist policy prevents extensions from being installed on the machine.
To fix this, you can either:
- Install the UiPath Extension using Group Policy.
- Or allow the UiPath Extension to be installed from the Edge Web Store by adding the value
cdfjcmjmgdnojgaojdnefhjjpaijapcito the ExtensionInstallAllowlist policy.
NativeMessagingUserLevelHosts
If the NativeMessagingUserLevelHosts policy is set to false, it prevents the UiPath extension from working correctly in the case it was installed without administrator privileges.
- Set the NativeMessagingUserLevelHosts policy to
true.
BlockExternalExtensions
If the BlockExternalExtensions policy is set to true, it prevents the UiPath extension from being installed in any other way except for by policy.
To fix this you can either:
- Set the BlockExternalExtensions policy to
false.
ExtensionAllowedTypes
If the ExtensionAllowedTypes policy is set, it prevents the UiPath Extension from being installed. To fix this, you must add the value extension to the ExtensionAllowedTypes policy.
ExtensionSettings
If the ExtensionSettings policy is set to block all extensions it will prevent the UiPath Extension from being installed.
BrowserCodeIntegritySetting
If the BrowserCodeIntegritySetting policy is set to Enabled, Microsoft Edge browser process restricts the UiPath Extension for Edge from interacting with UI elements outside the webpage (i.e., outside the DOM).
This is because starting with Windows version 104, Edge only allows Microsoft signed binaries to load. As a result, UI automation is blocked for components such as buttons in the address bar, the file download dialog, or the settings page.
To fix this, you must set the BrowserCodeIntegritySetting policy value to Disabled.
DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist
The DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist policies let you enable Developer Tools only for the UiPath extension ID, while keeping them disabled for all other extensions. This approach preserves your browser hardening posture and is the recommended option for managed or secured environments.
Both policies must be set for the change to take effect. If the DeveloperToolsAvailabilityBlocklist policy remains unset, the DeveloperToolsAvailabilityAllowlist policy value is not considered.
When both policies are correctly configured, full UiPath extension functionality is restored even if DeveloperToolsAvailability=2 (Disallow usage of the Developer Tools).
If DeveloperToolsAvailability is set to 2, the Chromium API input method does not work. To work around this limitation, use the Hardware Events input method.
Instead of configuring DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist, you also have the option to set DeveloperToolsAvailability Group Policy to the value 1 (Allow usage of the Developer Tools) to enable the full extension functionality.
However, we recommend the allowlist/blocklist policies option, as it enables you to specify only the UiPath extension ID, limiting the scope of the change to the required extension.
If neither DeveloperToolsAvailabilityAllowlist/DeveloperToolsAvailabilityBlocklist nor DeveloperToolsAvailability are configured, the Inject Js Script activity will not work.
- Group Policies that affect the UiPath Extension for Edge
- ExtensionInstallForcelist
- NativeMessagingBlocklist
- NativeMessagingAllowlist
- ExtensionInstallBlocklist
- NativeMessagingUserLevelHosts
- BlockExternalExtensions
- ExtensionAllowedTypes
- ExtensionSettings
- BrowserCodeIntegritySetting
- DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist
