document-understanding
Document Understanding user guide
Última atualização 6 de abr de 2026
Implantar o UiPathDocumentOCR
Create a UiPathDocumentOCR ML package in AI Center.
For online installation, the UiPathDocumentOCR model is already included in the Out of the box packages section.
For offline instalation, follow the steps included in the Upload model to AI Center section.
Go to ML Packages > Out of the box packages > UiPath Document Understanding > UiPathDocumentOCR, and select Submit.
Go to ML Skills and create a new ML skill for the UiPathDocumentOCR package you created.
Please use Advanced Infra Settings to update the deployment to update the replica (the number of replica should ideally be equal to the number of nodes) and maximize the CPU (at least 4) and RAM requests if you are not using GPU machines, or the UiPathDocumentOCR processing will be slow and may fail.
O mecanismo OCR precisa de GPU para desempenho ideal e é recomendado para cargas de trabalho de produção. No entanto, se a GPU não estiver disponível, o mecanismo ainda poderá ser executado na CPU, mas requer mais recursos do que o padrão. As configurações infra avançadas devem ser ajustadas como tal:
Replicas: increase if there is concurrent usage of UiPathDocumentOCR. If you are using UiPathDocumentOCR to do imports on a single Data Labeling session at a time and the UiPathDocumentOCR is not used in other UiPath® workflows then 1 replica suffices. Otherwise, the number of replicas needs to be increased. There is no "magic" number here, you need some trial and error. Do not use more than 2 replicas on a single node installation. Ideally, replica count should equal the number of nodes in the cluster (1 replica/node). If more parallelism is needed, increasing the CPU helps
CPU: it should be at least 4 (for each replica). Make sure you have appropriate resources. There is no "magic" number, but more CPU means faster processing time. You need to test under your specific scenarios what is enough.
It can take up to 30 minutes for the ML Skill to be ready. You may need to refresh the AI Center page for the status to change. Once the ML Skill is available, select the ML Skill and go to Modify current deployment.
Ative o botão de alternância para tornar a habilidade de ML pública. Pode ser necessário aguardar alguns minutos e atualizar a página.
Select the ML Skill and copy the URL, which is the endpoint of the UiPathDocumentOCR for later use.
Captura de tela da interface de Habilidades de ML.
Precisa de ajuda? Suporte
