Iniciar como um revisor técnico
After successfully logging in, you, as a Technical Reviewer need to focus on pushing forward automations by identifying code quality issues and approving automations for . To do this check the Automation Pipeline > Review page and review automations that are awaiting the technical review.
By accessing the Explore module you can:
Precisa de ajuda? Suporte
