Iniciar como um Usuário Padrão
After successfully logging in, you, as a Standard User are encouraged to Share Ideas and upload Components that will boost the company’s RPA assimilation to get inspired you can check out the list of Ideas shared for your tenant.
Within the Workspace module, you can have a detailed view over:
By accessing the Explore module you can:
Precisa de ajuda? Suporte
