studio
Guía de usuario de Studio
Plantillas de caso de prueba
Use test case templates as base models for your test cases. For example, you can create a template with data variations to be reused on different tests. You can create test case templates for Test Automation projects, including other file types such as Global Exception Handler. For other projects (e.g., Process), you can create workflow templates.
Condiciones​
  • Las plantillas son específicas para el tipo de proyecto y el lenguaje que se utiliza para crearlo.
  • Las plantillas no se pueden convertir en flujos de trabajo, compilados o publicados.
  • You can make use of reusable content by creating a library with test case templates. Test data variation is not exported to the library alongside the test case template.
    Importante:
    Los recursos referenciados en la plantilla no se copiarán localmente al proyecto en el que intentas importar la biblioteca.La plantilla no debería contener referencias a otros activos, como flujos de trabajo, en la biblioteca.
Fuentes de plantilla​
When you add a new file, you can choose a template on which to base it. The templates that you can choose from vary depending on the type of file you are adding (workflow or test case) and on whether you have previously added templates to your project Templates folder.
Plantillas incorporadas​
Caso de prueba vacío​
Choose Empty Test Case when you create a test case if you want to add a Placeholder activity that you want to invoke at a later stage.
Caso de prueba BDD​
BDD stands for Behavioural-Driven Development. Choose BDD Test Case when you create a test case to structure your test around Given-When-Then containers.
Plantillas de archivos locales​
The local templates are created in the Templates folder of the project when you extract a file as template and when you add a template to the Templates folder. Local file templates are available only inside the project where you create, or extract them.
You can create local templates of three types: execution template, workflow template, and test case template. When you extract a file as a template, the template type is applied automatically based on the type of file you extract (workflow or test case). When you manually add a template to the Templates folder, you select the type of template to create.
Plantillas de archivos de paquetes​
Prueba con tiempo de espera​
The Test With Timeout template is available only with the Testing activity package, version 22.10 or higher. Choose Test With Timeout when you create a test case if you want to use a timeout or to take screenshots when a verification fails.
La plantilla está configurada para lanzar una excepción basada en tiempo, tomando una captura de pantalla del fallo que se haya producido en tu flujo de trabajo.
Nota:
  • Si estableces la variable Boolean takeScreenshotOnException como false, asegúrate de modificar la propiedad Timeout Message de la actividad TimeoutScope.
  • Puedes modificar el tiempo de espera en la variable duration. El valor determinado está establecido en cinco (5) minutos.
  • Puedes guardar capturas de pantalla en tu máquina configurando los ajustes del Proyecto de prueba.
Añadir una Plantilla de archivo local​
You can use the contextual menu in the Project panel to manually add execution, and test case templates based on other templates to your project. After you add a template, you can edit it in the Designer, and then use it as a starting point for creating other files.
  • To add a test case template, right-click the Templates folder, and then select Add > Test Case Template. Follow the test case creation process to configure the template.
  • Para añadir una plantilla de ejecución, haz clic en la carpeta Plantillas y luego selecciona Añadir > Plantilla de ejecución.
Extraer archivo como plantilla​
  1. Abre tu flujo de trabajo en Studio.
  2. En el panel Proyecto, haz clic con el botón secundario en un caso de prueba y selecciona Extraer como plantilla.
Tu caso de prueba ahora está almacenado en Proyecto > Plantillas. Puedes copiar y pegar o moverlo a tu carpeta de pruebas.
Nota:
  • Puedes crear plantillas directamente desde la carpeta Plantillas para tus casos de prueba y flujos de trabajo.
  • You can use the contextual menu within the Templates folder to perform various actions, such as comparing files.
Plantillas de caso de prueba en Bibliotecas​
You can create test case templates in libraries the same way you create them in processes. After you publish the library, the templates marked as public are available as package file templates in projects where the library is installed.
Crear un Caso de prueba desde una Plantilla​
  1. Crea un Proyecto de prueba.
  2. Crea un caso de prueba que te gustaría usar como plantilla.
  3. When you finish building the test case, right-click it, and select Extract as Template.
    Name the template, choose the Templates folder as the location to store it in, and select Create. For this example, the name of the template is MyFirstTestCaseTemplate.
  4. Go to the Design tab, in the File group, select New > Test Case. The New Test Case window is displayed.
  5. Give it an appropriate name, and select the template that you previously created from the Template dropdown list. For this example, choose MyFirstTestCaseTemplate.
Eliminar una plantilla​
To remove a template, expand the Templates folder in the Project panel, right-click the template, and then select Delete.
