document-understanding
Última actualización 6 de abr. de 2026
Implementar UiPathDocumentOCR
Create a UiPathDocumentOCR ML package in AI Center.
For online installation, the UiPathDocumentOCR model is already included in the Out of the box packages section.
For offline instalation, follow the steps included in the Upload model to AI Center section.
Go to ML Packages > Out of the box packages > UiPath Document Understanding > UiPathDocumentOCR, and select Submit.
Go to ML Skills and create a new ML skill for the UiPathDocumentOCR package you created.
Please use Advanced Infra Settings to update the deployment to update the replica (the number of replica should ideally be equal to the number of nodes) and maximize the CPU (at least 4) and RAM requests if you are not using GPU machines, or the UiPathDocumentOCR processing will be slow and may fail.
El motor OCR necesita la GPU para un rendimiento óptimo, y se recomienda para cargas de trabajo de producción. Sin embargo, si la GPU no está disponible, puede seguir ejecutándose en la CPU, aunque requiere recursos superiores a los predeterminados. La configuración avanzada de infraestructura debe ajustarse como tal:
Replicas: increase if there is concurrent usage of UiPathDocumentOCR. If you are using UiPathDocumentOCR to do imports on a single Data Labeling session at a time and the UiPathDocumentOCR is not used in other UiPath® workflows then 1 replica suffices. Otherwise, the number of replicas needs to be increased. There is no "magic" number here, you need some trial and error. Do not use more than 2 replicas on a single node installation. Ideally, replica count should equal the number of nodes in the cluster (1 replica/node). If more parallelism is needed, increasing the CPU helps
CPU: it should be at least 4 (for each replica). Make sure you have appropriate resources. There is no "magic" number, but more CPU means faster processing time. You need to test under your specific scenarios what is enough.
It can take up to 30 minutes for the ML Skill to be ready. You may need to refresh the AI Center page for the status to change. Once the ML Skill is available, select the ML Skill and go to Modify current deployment.
Activa el selector para hacer pública la habilidad ML. Es posible que tengas que esperar unos minutos y actualizar la página.
Select the ML Skill and copy the URL, which is the endpoint of the UiPathDocumentOCR for later use.
Captura de pantalla de la interfaz de habilidades ML.
¿Necesita ayuda? Soporte
