document-understanding
Última actualización 6 de abr. de 2026
Utilizar el marco
As a Studio workflow, you could use the Document Understanding™ Process: Studio Template.
Use Document Understanding models (including UiPathDocumentOCR)
Please first check how to deploy UiPathDocumentOCR or an out-of-the-box ML Package on AI Center standalone.
Selecciona el flujo de trabajo en el marco, y selecciona la habilidad ML en el menú desplegable y añade la clave API. Si has instalado la versión sin conexión de AI Center de forma independiente, no se requiere ninguna clave API.
Nota:
You need to make sure the robot is connected to the same Orchestrator as AI Center.
Alternatively, you also have the option to use the public ML Skill endpoint. Just simply replace the endpoint with the public ML Skill endpoint from the deployed ML package following the instructions here and add the Document Understanding license key.
  • Endpoint: the public ML Skill endpoint from Deploy an out-of-the-box ML Package
  • ApiKey: copy it from Automation Suite (Admin > Licenses > Robot & Services > Document Understanding)
    Captura de pantalla del campo Clave API en la actividad Extractor ML de facturas.
Run the workflow. The robot will process the documents one by one. When the Validation Station pops up, select OK to test if the workflow is running properly.
  • Use Document Understanding models (including UiPathDocumentOCR)
¿Necesita ayuda? Soporte
