document-understanding
Última actualización 6 de abr. de 2026
Panel de consumo de Document Understanding y AI Center
Información general
Based on the actions performed in Document UnderstandingTM and AI Center, the dashboard offers a detailed view of the AI units consumption at tenant level.
Nota:
  • De forma predeterminada, no hay retención de datos para las implementaciones de Automation Suite.
  • To access the AI units consumption overview dashboard, you must purchase Insights and enable it for your tenant.
Nota:
  • Los datos se actualizan cada 24 horas.
  • If the value for Automation Name is displayed as Unknown, it means that there is no related data. This could result from using an older Robot or activity package version which is not reporting the needed data, or if the data resides in a different region. Make sure you update your Robot and activity packages to the latest version, so that the dashboard can collect all required data points.
  • El panel muestra todos los datos de un tenant y de la región en la que está disponible el tenant.
  • The dashboard includes AI units consumption data for Document Understanding and AI Center. For Document Understanding, the data covers both cross-platform DocumentUnderstanding.Activities and IntelligentOCR.Activities, applicable for both classic and modern projects, as well as consumption occurring by using API calls. Data is reported for pre-trained specialized, as well as custom models.
Captura de pantalla del panel de consumo de Document Undertanding y AI Center
Requisitos previos
To access the Document Understanding and AI Center unit consumption dashboard, Insights must be enabled on your tenant.
Si quieres realizar un seguimiento de las AI Units consumidas por trabajos que se ejecutan con UiPath Robots o por automatizaciones ejecutadas desde flujos de trabajo de UiPath Studio, asegúrate de que tus proyectos utilicen estas versiones o las más recientes:
  • UiPath Studio and Robot: 2023.6
  • UiPath.DocumentUnderstanding.Activities package: 2.9.1
  • UiPath.DocumentUnderstanding.ML.Activities package: 1.28.2
  • UiPath.IntelligentOCR.Activities package: 6.19.1
  • UiPath.MLServices.Activities: 2.0.2
Nota:
AI units consumed by the AI Center ML skills, based on out of the box packages that are older than version 22.10, are not displayed in the dashboard. Only the AI units consumed for infrastructure are displayed. AI units used for calling skills are not tracked and therefore are not displayed in the dashboard. Note that upgrading the ML packages version also implies retraining for retrainable models.
Filtros
Puedes elegir un período de tiempo específico para revisar el uso de las unidades de IA.
Métricas
Azulejo Descripción
Gráfico de consumo por proyecto AI Units consumidas, agrupadas por Document Understanding o proyecto de AI Center. La información se muestra en forma de gráfico de líneas.
Tabla de consumo por proyecto AI Units consumidas, agrupadas por Document Understanding o proyecto de AI Center. La información se muestra en forma de tabla con información adicional:
  • Project Name : name of the Document Understanding, or AI Center project used for consuming AI units.
  • Project Id : ID of the Document Understanding, or AI Center project used for consuming AI.
  • Project type : type of the project used for consuming AI units:
    • Proyecto moderno de Document Understanding
    • Proyecto clásico de Document Understanding
    • AI Center
    • N/A: se muestra para los flujos de trabajo de IntelligentOCR que no hacen referencia a un proyecto de Document Understanding.
  • AI units : total number of AI units consumed in the project.
  • Pages : total number of pages processed in the project.
Consumo por origen Unidades de IA consumidas, agrupadas por proyecto y operación Document Understanding o AI Center :
  • Project Name : name of the Document Understanding, or AI Center project where the operation was run.
  • Project Id : ID of the Document Understanding or AI Center project where the operation was run.
    • AI Center
  • Source : name of the operation used for consuming AI units (for example, model name, digitization, Intelligent Keyword Classifier, and so on).
  • Automation name : name of the automation used for consuming AI units.
    Note: If the value is displayed as Unknown , it means that there is no related data. This could result from using an outdated Robot or activity package version, or if API Keys were used to access public endpoints, such as du.uipath.com/invoices .
    The value is displayed as Unknown also in the case of suspended jobs. In this case, the entry is populated after the job resumes and the automation execution finishes.
  • NombreCarpetaOrchestrator
  • AI units : total number of AI units consumed by the operation.
  • Pages : total number of pages processed by the automation.
Gráfico de consumo por operación de AI Center AI Units consumidas correspondientes a las operaciones AI Center :
  • Consumo de tiempo de ejecución relacionado con predicciones utilizando modelos de AI Center (excluyendo Document Understanding).
  • Consumo de entrenamiento para entrenar el modelo.
  • Hosting para servir el modelo.
Tabla de consumo por recursos de AI Center Unidades de IA consumidas correspondientes a los recursos de AI Center utilizados, incluida la operación realizada. La información se muestra en forma de tabla con información adicional:
  • Project Name : name of the AI Center project where the operation was run.
  • Source : this can be one of the following:
    • Nombre de la habilidad ML utilizada para el alojamiento.
    • Nombre del paquete ML utilizado para el entrenamiento. Cuando el consumo se realiza desde la infraestructura de entrenamiento de AI Center, packageVersion se muestra entre corchetes.
    • Nombre de la habilidad ML utilizada para el tiempo de ejecución.
  • Type : the type of the operation used for consuming AI units:
    • Tiempo de ejecución
    • Formación
    • Alojamiento
  • AI units : total number of AI units consumed by the resource.
  • Información general
  • Requisitos previos
  • Filtros
  • Métricas
¿Necesita ayuda? Soporte
