2022.4
- Notas relacionadas
- Primeros pasos
- Permisos
- Empezar como
- Consola de administración
- Espacio de trabajo
- Explorar
- Paneles
- Compartir ideas o automatizaciones
- Mis tareas
- Notificaciones
- Recursos
- Studio Integration
- Integración de Task Capture
- Automation Store
- Recursos adicionales
Empezar como gestor de programas
After successfully logging in, you, as a Program Manager, need to access Workspace > Automation Pipeline in order to decide what ideas should progress in the implementation phases. Furthermore, you can check out and edit any information from the Idea Profile page as well as assign implementation teams for the shared ideas.
Te animamos a Compartir ideas y Cargar componentes que impulsen la asimilación de RPA de la empresa.
Apart from the Automation Pipeline page, you can check out all the other options available under the Workspace module if you want to have a detailed view over:
- Your ideas;
- Your collaborations;
- Your components;
- The Ideas you follow.
By accessing the Explore module you can:
- ver las idas compartidas por tus compañeros y seguir las que te interesen,
- check out and download the components shared within your tenant,
- access the Leaderboard.
