Empezar como gestor de programas
After successfully logging in, you, as a Program Manager, need to access Workspace > Automation Pipeline in order to decide what ideas should progress in the implementation phases. Furthermore, you can check out and edit any information from the Idea Profile page as well as assign implementation teams for the shared ideas.
Te animamos a Compartir ideas y Cargar componentes que impulsen la asimilación de RPA de la empresa.
Apart from the Automation Pipeline page, you can check out all the other options available under the Workspace module if you want to have a detailed view over:
By accessing the Explore module you can:
¿Necesita ayuda? Soporte
