Automation Hub api guide
- Open API
- Introduction to Automation Hub API
- Introduction to Automation Hub API (Automation Cloud Public Sector)
- API References
- Generate your Token from Automation Hub
- Authentication to the Automation Hub API
- Authentication to the Automation Hub API (Automation Cloud Public Sector)
- Add users in bulk to Automation Hub using OpenAPI
- Bulk edit users in Automation Hub using OpenAPI
- Delete an automation using OpenAPI
- Retrieve Automation Idea in Idea Phase Awaiting Review Status
- Retrieve the Cost Benefit Analysis for a Specific Idea
- Update Automation Idea Phase and Status
- Retrieve a User Account
- Update Account Details for Employees from Automation Hub
- Inactivate User Accounts that are Not Part of the Company
- Power BI Integration Video Tutorial
- Service Now Outbound Integration Video Tutorial
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
- Automation Hub Custom Connector
Video tutorial covering how to connect Power BI to the Automation Hub API to retrieve pipeline data and create custom dashboards in Automation Cloud Public Sector.
Applies to Automation Cloud Public Sector only.
**Short description:**This video presents how to GET Automation Pipeline Data to Power BI and create custom dashboards.
The main topics are:
- 00:00 Intro
- 01:00 Setting up the connection from Power BI
- 04:00 Getting the API credentials from Automation Hub
- 04:45 Parsing the JSON response from the Open API
- 05:55 Formatting the table columns
- 08:15 Creating a dashboard from the imported data
