Automation Hub api guide
Manage comments using OpenAPI
OpenAPI endpoints and uip ah CLI commands for listing, posting, editing, and deleting comments on ideas and business processes in Automation Hub.
List, post, edit, and delete comments on ideas and business processes by calling the /api/v1/openapi/automations/{id}/comments endpoints, or by using the uip ah automations comments commands.
Prerequisites​
  • You have an active Automation Hub API token. For instructions, see Generate your Token from Automation Hub.
  • You know the numeric ID of the idea or business process (automationId). To find it, use the Get Automations API request.
  • The user that the call acts as can view the idea or business process.
Authentication and authorship​
The comment author depends on the type of token you use:
TokenAuthor of the comment
Token tied to a userThe user of the token.
Token not tied to a userThe active Automation Hub user whose email address you pass in the submitter field. A call without a valid, active submitter returns 403.
The author must be able to view the idea or business process. You can edit or delete a comment only if you are its author.
Endpoints​
ActionRequestBody
List commentsGET /api/v1/openapi/automations/{id}/commentsNone. Optional query parameters: page and limit.
Post a commentPOST /api/v1/openapi/automations/{id}/commentstext, and optionally parent_comment_id and submitter
Edit a commentPUT /api/v1/openapi/automations/{id}/comments/{commentId}text, and optionally submitter
Delete a commentDELETE /api/v1/openapi/automations/{id}/comments/{commentId}submitter, in the JSON body, if the token is not tied to a user
Send the same authentication headers as for the other OpenAPI calls. For details, see Authenticating to your Automation Hub tenant.
HeaderValue
AuthorizationBearer <tenant-id>/<your-access-token>
x-ah-openapi-authopenapi-token
x-ah-openapi-app-keyYour API key, if you added one.
Content-Typeapplication/json, for POST and PUT requests
List comments​
The list returns top-level comments, newest first, each with its replies, author, and created and updated timestamps. Each comment is returned as plain text (text) and in its stored rich text (DraftJS) format (text_draftjs).
Query parameterDescription
pageThe page number, starting at 1. The default is 1.
limitThe number of top-level comments per page, up to 100. The default is 20. A value of 5 or less also returns 20.
Post a comment​
Send the comment as plain text of 1 to 2,000 characters. Line breaks are kept. To reply to a comment, set parent_comment_id to the ID of that comment.
  "text": "Approved for the next planning cycle.",
  "parent_comment_id": 1234,
  "submitter": "jane.doe@email.com"
The comment shows in the interface with the correct author and time. Automation Hub sends the same notifications (to followers, collaborators, mentioned users, and the author of the parent comment) as for a comment posted in the interface.
Edit a comment​
Send the new text of the comment, as plain text of 1 to 2,000 characters. The new text replaces the whole comment, including any @mentions it had. Plain text cannot add mentions, so an edit removes the existing ones, and Automation Hub sends no mention notifications.
  "text": "Approved for the next planning cycle, pending budget review.",
Delete a comment​
Automation Hub removes the comment from the idea or business process and updates the comment count of the automation. When you delete a reply, it also updates the reply count of the parent comment.
If the token is not tied to a user, send the email address of the comment's author in the submitter field of the JSON body.
Use the CLI​
ActionCommand
List commentsuip ah automations comments list <automation-id>
Post a commentuip ah automations comments add <automation-id> --text "<comment-text>"
Edit a commentuip ah automations comments edit <automation-id> <comment-id> --text "<comment-text>"
Delete a commentuip ah automations comments delete <automation-id> <comment-id>
The edit and delete commands accept the --submitter option, which takes the email address of the user the call acts as.
Error codes​
CodeMeaning
400Bad request. The request body or a parameter is not valid, for example when text is empty or longer than 2,000 characters.
403Forbidden. The user cannot view the automation, is not the author of the comment, or the token is not tied to a user and no valid submitter was passed.
404Not found. The idea or business process does not exist, or the comment does not exist on it or was already deleted.
Connect
Stay updated
