Automation Hub api guide
- Open API
- Introduction to Automation Hub API
- Introduction to Automation Hub API (Automation Cloud Public Sector)
- API References
- Generate your Token from Automation Hub
- Authentication to the Automation Hub API
- Authentication to the Automation Hub API (Automation Cloud Public Sector)
- Add users in bulk to Automation Hub using OpenAPI
- Bulk edit users in Automation Hub using OpenAPI
- Delete an automation using OpenAPI
- Retrieve Automation Idea in Idea Phase Awaiting Review Status
- Retrieve the Cost Benefit Analysis for a Specific Idea
- Update Automation Idea Phase and Status
- Retrieve a User Account
- Update Account Details for Employees from Automation Hub
- Inactivate User Accounts that are Not Part of the Company
- Power BI Integration Video Tutorial
- Service Now Outbound Integration Video Tutorial
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
- Automation Hub Custom Connector
API call pattern for updating an automation idea's phase and status in Automation Hub, with an example advancing an idea to Assessment in Progress.
Use this call to easily keep your Idea phase and status updated. Below you can find an example of how to make a call in which the Idea phase is updated to status Assessment in Progress.
Note:
The API base URL format varies by deployment environment. For the correct base URL for your environment, see Introduction to the Automation Hub API.
Post: https://<accessURL>/{orgName}/{tenantName}/automationhub_/api/v1/openapi/automations/status
Request
Headers
Authorization: Bearer [Tenant ID/Token]
x-ah-openapi-auth: openapi-token
data-raw '{
"process_id": 1183,
"phase_status_id": 53
Headers
data-raw '{
"process_id": 1183,
Response
"message": "Resource Updated",
"statusCode": 201,
"data": {
"message": "Sync Successful."
"statusCode": 201,
"data": {
