Automation Hub api guide
Input for Automation Idea Creation Date
EPOCH date format requirements for filtering automation ideas by creation date or update date in Automation Hub API calls.
Note:
For both Automation Idea Creation Date and Automation Idea Update Date filters the used date format is EPOCH.
Note:
The following video tutorial about the EPOCH date format is available for Automation Cloud Public Sector only. Watch the EPOCH date format video tutorial.
KeyValueUse Case
createdStartThe start date for the search.GET filter
createdEndThe end date for the search.GET filter
Examples
  • Retrieve all Automation Ideas created after 23/07/2020: createdStart=1595462400
  • Retrieve all Automation Ideas created before 23/07/2020: createdEnd=1595462400
  • Retrieve all Automation Ideas created between 22/07/2020 and 23/07/2020: CreatedStart=1595376000&createdEnd=1595462400
  • Examples
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
