Automation Hub api guide
Making Automation Hub API Calls
How to structure Automation Hub API calls using Bearer token authorization and optional App Key headers in Automation Cloud.
  • Define the token as a bearer -H 'Authorization: Bearer [Tenant ID]/ [Token_generted_from_the_Open API_page].
  • If an App Key was defined when generating the token, it's mandatory that you apply it using the following key: x-ah-openapi-app-key: [defined app key]
  • Adding x-ah-openapi-auth: openapi-token key in the header is mandatory as it indicates the token type.
Note:
The API base URL format varies by deployment environment. For the correct base URL for your environment, see Introduction to the Automation Hub API.
The easiest way to build the Automation URL is by using the process_slug.
For example, if the process_slug is: process_slug": "onboarding-of-new-employee"
Then the URL for that automation is: https://automation-hub.uipath.com/{tenantName}/process_slug/onboarding-of-new-employee
The request should look as in the following example:
Authorization: Bearer [Tenant ID/Token]
  • Use the Copy to Clipboard option available after the Token column to copy-paste your [Tenant ID\Token] value from your Automation Hub Open API page as described in the Generate your Token page.
  • If an App Key is included for your token, a Copy to Clipboard option becomes available after the App Key column. Use it to copy-paste your [App Key] value.
Note:
The [Token] required for making Automation Hub API calls has limited validity. In case this expired, edit the expiration date by accessing the Actions > Edit option from the Action column corresponding to the token OR generate a new token as mentioned in the Generate your Token page. Otherwise, you will receive a 401 status code.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
