Automation Hub api guide
Input for Category
Input parameter values for the Category field in Automation Hub API calls, using the lowest-level category ID to capture the full hierarchy chain.
Note:
Use the lowest Category ID in order for the whole hierarchy chain to be inputted.
KeyValueUse Case
hierarchyThe Category values are not defined as these fields are customized by each tenant.GET and POST request parameters
Note:
You can easily extract the Category values relevant for your tenant by using the GET category call.
Example: "category=717" where 717 is a level 3 Category used in order to input the whole Category chain (the Level 1 Category, the Level 2 Category, and the Level 3 Category).
UI Correspondent​
  • Categories
  • UI Correspondent​
Connect
Stay updated
