Automation Hub api guide
- Open API
- Introduction to Automation Hub API
- Introduction to Automation Hub API (Automation Cloud Public Sector)
- API References
- Generate your Token from Automation Hub
- Authentication to the Automation Hub API
- Authentication to the Automation Hub API (Automation Cloud Public Sector)
- Add users in bulk to Automation Hub using OpenAPI
- Bulk edit users in Automation Hub using OpenAPI
- Delete an automation using OpenAPI
- Retrieve Automation Idea in Idea Phase Awaiting Review Status
- Retrieve the Cost Benefit Analysis for a Specific Idea
- Update Automation Idea Phase and Status
- Retrieve a User Account
- Update Account Details for Employees from Automation Hub
- Inactivate User Accounts that are Not Part of the Company
- Power BI Integration Video Tutorial
- Service Now Outbound Integration Video Tutorial
- Input for Automation Pipeline
- Input for Submission Type
- Input for Phase
- Input for Status
- Input for Phase and Status Update
- Input for Business Unit
- Input for Applications
- Input for Category
- Input for Cost Benefit Analysis
- Input for High Level Assessment
- Input for Detailed Assessment
- Input for Automation Idea Creation Date
- Input for Users
- Input for User Status
- User Status Table
- Input for Collaborators
- Output Dictionary
- Automation Hub Open API Power Query Data Parsing
- Automation Hub Custom Connector
Input parameter values for the Collaborators field in Automation Hub API calls, used to retrieve users assigned collaborator roles on a specific automation idea.
The GET Collaborators call allows users to retrieve all the users assigned with a collaborator role within a specific automation idea.
Note:
As an input parameter use the automation ID, in order to identify the Automation Idea for which you want to retrieve the list of collaborators.
| Key | Value | Use Case |
| collaborators | Automation ID | GET request parameter |
Example: collaborators=72 where 72 is the automation ID
UI Correspondent: Collaborators.
