uipathctl 参考指南
新发布内容的本地化可能需要 1-2 周的时间才能完成。
uipathctl manifest list-applications
有关 uipathctl Manifest list-applications 命令的参考,该命令列出了从 Automation Suite 中的配置文件创建的应用程序。
描述​
加载在参数中找到的配置文件,并列出基于该文件创建的应用程序。 Runtime 配置用于确定所需的应用程序。 输出始终采用表格格式。 默认情况下,列表按字母顺序排序。
uipathctl manifest list-applications PATH [flags]
示例​
# List the applications which are installed based on the configuration found in input.json
uipathctl manifest list-applications input.json
# List the applications which are installed based on the configuration found in input.json.
# Sort them by the order in which they need to be installed based on dependencies between them.
uipathctl manifest list-applications input.json/cluster_config.json --sort-by topological
# List the applications without headers
uipathctl manifest list-applications input.json/cluster_config.json --no-headers
# Override the initial list of enabled components
uipathctl manifest list-applications input.json/cluster_config.json --override gatekeeper,redis
选项​
  -h, --help                 help for list-applications
      --is-required string   to check whether the component needs to install
      --no-headers           if true, print the output without headers
      --override strings     optional list of components to override the components enabled in input.json/cluster_config.json file
      --sort-by sortBy       if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical)
从父命令继承的选项​
  • 描述​
  • 示例​
  • 选项​
  • 从父命令继承的选项​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
