uipathctl 参考指南
- 概述
- 预安装
- 安装
- 集群管理
- uipathctl cluster
- uipathctl 集群维护
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl 版本
- 备份和还原
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- 证书管理
- 升级
- 身份验证
- 监控和警示
- 特定于产品的配置
- 故障排除
新发布内容的本地化可能需要 1-2 周的时间才能完成。
uipathctl 运行状况捆绑包
uipathctl runtime 捆绑包命令及其标志的参考,用于生成支持捆绑包,以对 Automation Suite 的问题进行故障排除。
描述
生成可用于对 Automation Suite 问题进行故障排除的支持捆绑包。
uipathctl health bundle [PATH] [flags]
示例
Generate the bundle in the OS temporary directory
uipathctl health bundle input.json
Generate the bundle in a specific directory
uipathctl health bundle input.json/cluster_config.json --output-dir /foo/bar
Generate the bundle without additional health/prereq report
uipathctl health bundle input.json/cluster_config.json --skip-diagnose
选项
-h, --help help for bundle
-p, --include-previous If false, skips printing the logs for the previous instance of the container in a pod if it exists. (default true)
--limit-bytes int Maximum bytes of logs to return. Defaults to no limit.
--output-dir string path to output directory
--since-time string Only return logs after a specific date (RFC3339). Defaults to all logs.
--skip-diagnose skip additional health/prereq report
--versions string path to versions file
从父命令继承的选项
--excluded strings components to be excluded from execution, defaults to none
--included strings components to be included in the execution, defaults to all
-o, --output output output format. one of [json,yaml,text,junit] (default text)
