- 概述
- 预安装
- 安装
- 集群管理
- uipathctl cluster
- uipathctl 集群维护
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl 版本
- 备份和还原
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- 证书管理
- 升级
- 身份验证
- 监控和警示
- 特定于产品的配置
- 故障排除
uipathctl manifest get
uipathctl 参考指南
Last updated 2024年11月11日
在标准输出上打印在集群中观察到的当前清单。格式始终为
YAML
该命令将默认为
kubeconfig
文件中的当前上下文。如果设置了 --kubeconfig
标志,则它将使用标志指定的 kubeconfig
文件。如果没有其他标志,输出中不包含集群范围内的配置和依赖项。
uipathctl manifest get [flags]
# Get the current manifest observed in the cluster, without dependencies or cluster wide configurations
# Get the current manifest from the cluster identified by the current context in the kubeconfig file
uipathctl manifest get --kubeconfig /root/kubeconfig
# Get the current manifest, including the cluster wide configurations and the dependencies
uipathctl manifest get --include-config --include-dependencies
-h, --help help for get
--ignore-errors ignore errors when getting the manifest
--include-config include cluster wide config in the diff
--include-dependencies include dependencies in the diff
-o, --output output output format. one of [json,yaml] (default yaml)
