uipathctl 参考指南
- 概述
- 预安装
- 安装
- 集群管理
- uipathctl cluster
- uipathctl 集群维护
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl 版本
- 备份和还原
- uipathctl 快照
- uipathctl 快照备份
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- 证书管理
- 升级
- 身份验证
- 监控和警示
- 特定于产品的配置
- 故障排除
新发布内容的本地化可能需要 1-2 周的时间才能完成。
uipathctl manifest diff
有关 uipathctlmanifestdiff 命令的参考,该命令可将配置文件与 Automation Suite 中的实时集群状态进行比较。
描述
加载作为参数提供的配置,并将其与集群中的实时配置进行比较。
如果不使用任何标志,则仅比较清单,而忽略集群范围内的配置和依赖项。
输出始终为YAML 。默认情况下,路径中可用的 diff 命令与u (统一差异)、 -N (将不存在的文件视为空)和--color (颜色输出)一起运行。添加--no-color标志以禁用颜色输出。
uipathctl manifest diff PATH [flags]
示例
# Diff manifest found in input.json
uipathctl manifest diff input.json
# Diff manifest found in input.json, using the configuration found in cluster.kubeconfig
uipathctl manifest diff input.json/cluster_config.json --kubeconfig cluster.kubeconfig
# Diff manifest found in input.json, including cluster wide configurations and dependencies
uipathctl manifest diff input.json/cluster_config.json --include-dependencies --include-config
选项
-h, --help help for diff
--include-config include cluster wide config in the diff
--include-dependencies include dependencies in the diff
--no-color disable color output
从父命令继承的选项
