Process Mining
Last updated Feb 18, 2026
Create a destination connection
Setup credentials for Azure Blob
To set up an Azure Blob destination connection, you need the following setup credentials for the Azure Blob.
  • account
  • URI
  • azure shared access signature (SAS uri)
These credentials are located in the url of the Azure blob storage to which the extracted data needs to be uploaded.
Setup the Azure Blob destination connection
Follow these steps to create the Azure Blob destination connection.
StepAction
1Define a new connection of type Azure Blob.
2Enter a descriptive name for the destination connection. For example, AzureBlob_IM.
3
  • Enter the URI azureblob://<container>/ as the URL.
  • Enter <account> as the Azure Storage Account
4
  • Select AzureStorageSAS as the Auth Scheme.
  • Enter the Azure Shared Access Signature (SAS uri).
5Create and test the connection.
  • Setup credentials for Azure Blob
  • Setup the Azure Blob destination connection
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
