Process Mining
Last updated Jun 3, 2025
Configuration settings for loading input data
Settings.json
Important:
The AddRawTablePostfix and StripSpecialCharacters settings in the settings.json file are no longer supported and cannot be used anymore to switch existing process apps to the data loading behavior that was introduced in March 2023.
When uploading data, always make sure that the input data is in the required format for the app template that you use to create the process app. Refer to App Templates.
If the settings.json file of your process app still contains these settings, you can safely remove them since they are not used anymore.
Setting
Format
AddRawTablePostfix
boolean
For adding a _raw suffix to your source tables when using file uploads through the Upload data option. For example, if the file you upload is named Event_log.csv it changes to Event_log_raw.csv if this setting is set to true.
boolean
For removing special characters and replacing spaces with underscores in table names and/or field names. For example, a field called Event+end changes to Eventend.
