- Release notes
- Before you begin
- Managing access
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Process simulation
- Root cause analysis
- Simulating automation potential
- Starting a Task Mining project from Process Mining
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Tips for writing SQL
- Exporting and importing transformations
- Viewing the data run logs
- Merging event logs
- Configuring Tags
- Configuring Due dates
- Configuring fields for Automation potential
- Activity Configuration: Defining activity order
- Making the transformations available in dashboards
- Data models
- Adding and editing processes
- Customizing dashboards
- Publishing process apps
- App templates
- Notifications
- Additional resources
Process Mining
Integrated extractors
linkGeneric
linkMessage: An instance terminated unexpectedly. Job was cancelled.
Possible solution
Contact UiPath Support for help.
Message: Required tables (or fields) not accessible from source.
Possible cause
The root cause of this error is the lack of table or field level access for the user configured in the extraction connection.
Possible solution
Either remove the table or field or ensure the user has access to all tables and fields selected for the data extraction.
Message: Table([TableName]): Deleted intermediate tables but no new files found. Failed loading data into table [TableName].
Possible cause
When you try to extract data from a source system using a direct connection and a table does not have any data associated with it, the following message can occur.
The following illustration shows an example.
- Go to Data transformations.
- In File storage manager, delete the tables.
- Configure a direct connection and make sure the table is set as non-mandatory.
Salesforce connection
linkMessage: [0] [sf:OPERATION_TOO_LARGE] OPERATION_TOO_LARGE: exceeded 100000 distinct ids.
Possible cause
The root cause of this error is the lack of a specific permission (View All Data) for the user configured in the extraction connection.
Possible solution
Reduce your date range filter to extract less data.
Refer to the official Salesforce documentation for a detailed description of the resolution for this error.
Message: Required tables not accessible from source. blng__CreditNote__History, blng__CreditNote__c, blng__CreditNoteAllocation__c …
Possible cause
The root cause of this error is that Salesforce Billing package is not installed or the user configured in the extraction connection does not have access to its tables.
Possible solutions
Check whether the Salesforce Billing package is installed.
Make sure the user configured in the extraction connection has access to the tables and fields specified in the app template. Refer to App Templates for details.
Message: Required tables not accessible from source. SBQQ__Quote__History, SBQQ__Quote__c
Possible cause
The root cause of this error is that Salesforce CPQ package is not installed or the user configured in the extraction connection does not have access to its tables.
Possible solutions
Check whether the Salesforce CPQ package is installed.
- Generic
- Message: An instance terminated unexpectedly. Job was cancelled.
- Message: Required tables (or fields) not accessible from source.
- Message: Table([TableName]): Deleted intermediate tables but no new files found. Failed loading data into table [TableName].
- Salesforce connection
- Message: [0] [sf:OPERATION_TOO_LARGE] OPERATION_TOO_LARGE: exceeded 100000 distinct ids.
- Message: Required tables not accessible from source. blng__CreditNote__History, blng__CreditNote__c, blng__CreditNoteAllocation__c …
- Message: Required tables not accessible from source. SBQQ__Quote__History, SBQQ__Quote__c
