document-understanding
Document Understanding user guide
Dernière mise à jour 6 avr. 2026
Introduction
The UiPath® Document UnderstandingTM framework facilitates the processing of incoming files, from file digitization to extracted data validation, all in an open, extensible, and versatile environment.
Document Understanding est conçu pour vous aider à combiner différentes approches d'extraction d'informations de plusieurs types de documents. Son principal objectif consiste à rendre le processus d'extraction de données aussi simple que possible : créer un workflow unique qui extraie les données de plusieurs documents.
Avant d'utiliser l'infrastructure Document Understanding, il est recommandé de comprendre les composants suivants de l'infrastructure Document Understanding :
  • Taxonomie What documents need to be processed and what data is required from them? Used to define the document types and the pieces of information targeted for data extraction (fields) for each document type, and formalizes this information into a dedicated Taxonomy structure. This metadata information is managed through the Taxonomy Manager.
  • Numérisation What does this file contain? Used to obtain the textual content and the structure of the incoming document, turning a file into machine-readable content so it can be further processed downstream.
  • Classification de document What types of documents from the taxonomy are found in this file? Used to automatically determine what document types are found within a digitized file.
  • Administrateur de la classification de document Is the predicted classification correct? This is how I can review and correct it. Used for assisting in the human validation and correction of the automatic classification and document splitting results.
  • Apprentissage de la classification Did the human review the data? This is how the robot can learn from it. Used to pass the human validated information back to the classifiers, to use it to improve their future predictions.
  • Extraction de données What data can be found in this particular document? Used to capture the information required for the identified document type, within the given input document and classification page range.
  • Validation de l'extraction de données Is the extracted information correct? This is how I can review and correct it. Used for assisting in the human validation and correction of the automatically extracted data results.
  • Apprentissage de l'extraction de données Did the human review the data? This is how the robot can learn from it. Used to pass the human validated extracted data back to the extractors, to use it to improve their extraction predictions.
  • Data Consumption Used to export the validated data in order to consume it.
  • Metering & Charging Logic Used to explain the consumption of units per page for each available service.
Le diagramme suivant présente les composants de l'infrastructure de Document Understanding et leurs relations mutuelles :
Diagramme décrivant l'infrastructure de Document Understanding.
The Document Understanding framework is found in the UiPath.IntelligentOCR.Activities package. Once the UiPath.IntelligentOCR.Activities package is installed, the Taxonomy Manager wizard appears in the top ribbon of the UiPath Studio. This same package contains all the core document understanding framework activities.
The scope activities (Classify Document Scope, Data Extraction Scope, Train Classifiers Scope, Train Extractors Scope) that are part of the Document Understanding framework allow you to use any document classification and data extraction algorithms that fit your use case and then train these algorithms.
The Document Understanding framework can be used not only with the out-of-the-box classifiers and extractors but also with any custom-built ones. These can be created using the abstract classes from the UiPath.DocumentProcessing.Contracts package and can be implemented as classification or data extraction activities. Custom-built OCR engines can also be created using the abstract classes from the UiPath.OCR.Contracts package.
Ressources
Dedicated Document Understanding courses can be found in the UiPath RPA Academy.
Le forum de la communauté UiPath permet d'obtenir le soutien de notre communauté d'utilisateurs toujours croissante.
  • Ressources
