Automation Suite admin guide
- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Testing tools available in Automation Suite, including Studio, Orchestrator, Robot, and Test Manager, and how they contribute to a complete testing project.
The tools directly involved in performing testing with the UiPath platform comprise of the following tools: Studio, Orchestrator, Robot, and Test Manager. In addition to these, all the other services that the UiPath platform offers contribute to creating a robust testing project, from start to finish. Check out the following list to learn about every testing component and how it works:
- Studio: The IDE for test automation development, including both application and automation testing, enabling you to create test cases, using either a low-code or coded approach, depending on your editing needs, if you prefer a more visual approach, or a full coded experience.
- Orchestrator: The tool that allows you to publish and execute your tests, via Test Manager or using a CI/CD pipeline.
- Testing robots: Used for running unattended automations for both development and testing purposes.
- Test Manager: The test management tool, and the ALM integrations that Test Manager offers.
