Automation Suite admin guide
Last updated May 30, 2025
My notifications
You can manage your notifications using the My Notification view from the Notifications settings page. Visit Notifications settings to learn more.
Learn about the experience of working with your notifications, by reading about how to manage them in the Notifications panel, and about the notification events you can subscribe to.
Viewing and accessing notifications
You can access notifications through the Notifications panel only.
To access the Notifications panel, go to the top navigation bar and select the bell icon. The Notifications panel displays notifications ordered by date, in descending order. The Notifications panel displays notifications from newest to oldest.
To access a specific notification, select the desired notification frame.
Viewing and accessing email notifications
Displaying only unread notifications
To display unread notifications, select the Unread only checkbox in the Notifications panel.
Marking all notifications as read
To mark all notifications as read:
  • In the Notifications panel, select More Action on All Notifications at the bottom of the Notifications panel and then select Mark all as read.
Clearing all notifications
To clear all notifications from the Notifications panel:
  • In the Notifications panel, select More Action on All Notifications at the bottom of the Notifications panel and then select Clear all.
Deleting notifications
You can delete notifications individually. To delete a notification:
  1. Go to a notification from the Notifications panel and select Action on Notification'Action on notification' image.
  2. Select Delete.
Selecting Delete permanently deletes a notification.
Subscribing to events
You can subscribe to certain events to receive notifications about them. Subscribe to events in the Notifications settings page. Visit to learn more.
Note:
The Automation Cloud column is visible for services with in-app notifications enabled. The Email column is visible for services with email notifications enabled.
Subscribing to an event:
  1. Go to the Notifications settings page.
  2. Go to a service tab and then go to the Automation Cloud or Email column.
  3. Select the checkbox that is inline with the event that you want to subscribe to.
    If you want to receive both in-app and email notifications on an event, then select both checkboxes under Automation Cloud and Email column.
Subscribing to all events:
  3. Select the Automation Cloud or Email checkbox to subscribe to notifications on all events.
Unsubscribing from events
To stop receiving notifications, you can unsubscribe from certain events. You can unsubscribe from events from the Notifications panel or from the Notifications settings page.
Note:
Unsubscribing from the Notifications panel:
  1. Access the Notifications panel.
  2. Go to a notification and select the Action on Notificationdocs image menu.
  3. Select Unsubscribe from <event>.
Unsubscribing from the Notification settings page:
  1. Go to the Notification settings page.
  2. Go to a service tab and then go to the Automation Cloud column.
  3. Deselect the checkbox that is inline with the event that you want to unsubscribe from.
    If you want to unsubscribe from both in-app and email notifications for an event, then deselect both checkboxes under Automation Cloud and Email.
Unsubscribing from all events
  2. Go to a service tab and then go to the AutomationCloud or Email column.
  3. Deselect the Automation Cloud or Email checkbox to unsubscribe from notifications about all events.
Warning: Unsubscribing from all the events of a service, via both Automation Cloud and Email, generates the following warning: "You’re not subscribed to receive any notifications from this service."
The Restore default subscriptions option restores the default subscriptions for notifications received both on Automation Cloud and Email.
