Automation Suite admin guide
Testing in your organization
UiPath supports testing across two major categories:
  • Automation testing: It is also referred to as RPA testing, and focuses on validating your automations to ensure that the workflows you build in UiPath behave as expected.
  • Application testing: Covers end-to-end testing of your enterprise applications, such as web or mobile apps, ensuring they meet your business and performance requirements. With the UiPath testing capabilities you can validate your automations and test external enterprise applications, reagrdless of whether they are automated using UiPath.
Automation testing
Automation testing helps ensure the reliability of your RPA workflows. UiPath helps you overcome common challenges such as complex process coverage, test data management, integration with ALM tools, and visibility over results. With UiPath, you can:
  • Design low-code or coded tests in Studio.
  • Execute and manage test sets in Orchestrator.
  • Gain full artifact traceability and manage your test portfolio in Test Manager.
You can also perform data-driven testing, and integrate with CI/CD pipelines.
Application testing
Application testing allows you to test enterprise apps with powerful UI and API automation. When performing application testing, UiPath offers the following:
  • Flexible automation development in Studio, using either low-code or full-code options.
  • Advanced testing activities via the Testing and Mobile Automation activity packages.
  • Scalable test execution using Testing robots.
  • Centralized test management and traceability with Test Manager.
  • Deep integration with ALM tools via Test Manager Connect or native connectors.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
