- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
Last updated Nov 11, 2025
Organization administrators can choose to override the email settings for sending system notifications that were defined at
the host level. The settings defined at the organization level apply for the current organization only.
Note: If already configured, you do not have to customize these settings unless you want to make changes compared to the host-level
setup. If you do not make any changes, the host configuration applies.
To override the settings for system emails:
- Go to Admin, select your organization at the top of the left pane, and then select Settings.
- Select the Email tab.
- Make changes as needed.
- Select Save in the bottom-right to apply your changes.
