- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Notifications
- Logging
- Troubleshooting
Automation Suite Admin Guide
Personal Access Tokens
A Personal Access Token (PAT) is a unique alphanumeric string that serves as a substitute for your credentials and grants you controlled access to specific UiPath resources while maintaining a high level of security.
As an admin, you have access to all the PATs generated within your organization. You can view key details such as the PAT owner, access scopes, the last usage date, and expiration date of the PAT.
PATs are currently limited to users with local accounts only.
To enable/disable PATs for all users in the organization, follow these steps:
In the Admin section for the organization, go to External Apps, and then select the Personal Access Token tab to display the PAT configuration window.
Click Settings and on the Settings window, turn on or off the Enable/Disable PAT for all users option to enable or disable the PAT functionality.
On the Maximum Lifespan field, enter the validity duration of a PAT in the organization. This duration represents the timeframe after which the PAT expires.
Click Save to save your changes or Cancel to return to the previous window without saving your changes.
As an admin, you have access to all the PATs generated within your organization. You can view key details such as the PAT owner, access scopes, the last usage date, and expiration date of the PAT. Based on this information, you can select specific PATs and revoke them as follows:
