Automation Suite admin guide
- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Testing tools
The UiPath testing tools including Studio, Orchestrator, Robot, and Test Manager in Automation Suite.
The tools directly involved in performing testing with the UiPath platform comprise of the following tools: Studio, Orchestrator, Robot, and Test Manager. In addition to these, all the other services that the UiPath platform offers contribute to creating a robust testing project, from start to finish. Check out the following list to learn about every testing component and how it works:
- Studio: The IDE for test automation development, including both application and automation testing, enabling you to create test cases, using either a low-code or coded approach, depending on your editing needs, if you prefer a more visual approach, or a full coded experience.
- Orchestrator: The tool that allows you to publish and execute your tests, via Test Manager or using a CI/CD pipeline.
- Testing robots: Used for running unattended automations for both development and testing purposes.
- Test Manager: The test management tool, and the ALM integrations that Test Manager offers.
