Automation Suite admin guide
Overriding System Email Notifications
Organization administrators can choose to override the email settings for sending system notifications that were defined at the host level. The settings defined at the organization level apply for the current organization only.
Note: You do not have to customize these settings unless you want to make changes compared to the host-level setup. If you do not make any changes, the host configuration applies.
To override the settings for system emails:
  1. Go to Admin > Organization Settings and select the Email tab.
  2. Make changes as needed.
    For information about the settings on this page, see Configuring system email notifications.
  3. Click Save in the bottom-right to apply your changes.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
