Automation Suite admin guide
- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Overriding system email settings
Override host-level email notification settings at the organization level in Automation Suite.
Organization administrators can choose to override the email settings for sending system notifications that were defined at the host level. The settings defined at the organization level apply for the current organization only.
Note:
If already configured, you do not have to customize these settings unless you want to make changes compared to the host-level setup. If you do not make any changes, the host configuration applies.
To override the settings for system emails:
- Go to Admin, select your organization at the top of the left pane, and then select Settings.
- Select the Email tab.
- Make changes as needed.
- Select Save in the bottom-right to apply your changes.
