Automation Hub user guide
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Submit a new entry
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Studio Integration
- Task Capture Integration
- Automation Store
- Additional Resources
Submitting automation ideas from UiPath Process Mining directly to Automation Hub using the Process Mining integration on Automation Suite 2024.10.
The integration with Process Mining enables you to send automation ideas from Process Mining directly to Automation Hub. For more details check Sending Automation Ideas to UiPath Automation Hub page.
