Automation Hub user guide
Submitting an Idea From UiPath Process Mining
Automation ideas from UiPath Process Mining can be submitted directly to Automation Hub using the Process Mining integration on Automation Suite.
The integration with Process Mining enables you to send automation ideas from Process Mining directly to Automation Hub. For more details check Sending Automation Ideas to UiPath Automation Hub page.
Connect
Stay updated
